KRC2 ProfiNet
  • SkyeFire
  • January 7, 2019 at 3:13 PM
    SkyeFire
    1,051
    9,423
    Some old documents on KRC2 ProfiNet setup that may be useful.
    Files
    Profinet_CP_1616_en.pdf 1.15 MB – 776 Downloads KRC2 ProfiNet.zip 1.95 MB – 612 Downloads
  • jarzhinom@5299
    7
    • May 2, 2024 at 3:37 PM
    good day
    do you perhaps have the Profinet IO option CD that is required for this setup
    SkyeFire
    1,051
    9,423
    • May 2, 2024 at 4:55 PM
    It came with the ProfiNet Card. Also, which version of the PN driver to use depends heavily on the KSS version the KRC is running, and the hardware/firmware revision of the PN card.
  • jarzhinom@5299
    7
    • May 3, 2024 at 9:01 AM
    thank you for your reply. first the cd they sent with the card does not install on the robot controller not sure if I am suppose to install it on there. the kss v 5.6 profinet card is 6gk1161-6AA2 . according to the setup mannual its suppose to be installed on the robot controller.
    SkyeFire
    1,051
    9,423
    • May 3, 2024 at 2:53 PM
    Quote from jarzhinom@5299
    How, exactly, does it "not install"? Describe what you did and what happened (or failed to happen).
    The PN driver is critical for the operation of the card. If your KRC2 is running KSS 5.6, then it should support USB. You may be able to copy the CD's contents onto a USB stick using another computer, then install on the KRC from the USB.
  • panic mode May 3, 2024 at 3:30 PM
    Moved the thread from forum Manuals, Software and Tools for KUKA Robots to forum KUKA Robot Forum.
  • jarzhinom@5299
    7
    • May 6, 2024 at 8:36 AM
    i have managed to install it. but it does not add a file to the kuka option. Do you perhaps have the copy on your robot that you can send me as its a new install for me. thanks
    SkyeFire
    1,051
    9,423
    • May 6, 2024 at 4:57 PM
    What does this mean? If it installed properly, you should now be able to carry out the configuration.
  • jarzhinom@5299
    7
    • May 6, 2024 at 5:03 PM
    Good day. Okay, sorry, here is how it is: I did not buy the card from Kuka as they don't have this card, so I bought it directly from Siemens. It only came with Siemens discs, which I installed, but I guess it needs the Kuka Profinet CD, which they no longer sell. So, this is the issue I am sitting with."
    SkyeFire
    1,051
    9,423
    • May 6, 2024 at 5:18 PM
    If you had said that up front, you could have saved everyone a lot of wasted time. Unfortunately, all my Profinet work was with KRC4s, not KRC2s, so I don't have any of the installers for KRC2s. Also, I'm not 100% certain the Siemens card will function in a KRC -- I don't know if the KUKA version had any firmware modifications to work with the KUKA driver, or if the hardware/firmware was 100% "Siemens stock".
  • DannyDJ
    67
    503
    • May 6, 2024 at 11:28 PM
    PROFINET CP_1616 card from Siemens works ok with KRC2 ed05. I have done couple of projects in past with PROFINET on KRC2 ed05 and using CP_1616.
    Problem now is that you need to install KUKA PROFINET driver for KRC2, but KUKA no longer supports or sell the software for KRC2.
  • jarzhinom@5299
    7
    • May 14, 2024 at 9:18 AM
    • #11
    thanks for the response, its fine i got the sofware file now. only software i do not have is kss 5.4 or kss 5.5 do you perhaps know were i can get it? the kss versions i have is 5.2.9 and 5.6.9.
    panic mode
    1,278
    13,079
    • May 14, 2024 at 1:00 PM
    • #12
    From Kuka of course... That is if they are willing to deal with something they stoped dealing with decades ago.
