Hello.
Its possible use a linear movement in IRB6000M93 S3?
Linear movement S3 IRB6000M93
szkyrp -
November 26, 2018 at 1:05 PM -
Hello.
set the coordinates to rectangular
How can I do this?
Use the "f" key then SCAN (extreme right soft key) until you see COORD, select and you should now have ROBOT RECT MODRECT, select RECT, just remember you have to execute the command (run the program) to make the RECT command active.
