Hello. Im have a problems with configuration. Im change a board And system dont see the IO board DSQC 223. And how i can check the board adress.
Connect IO board
szkyrp -
November 13, 2018 at 6:01 PM -
What version of controller? Most likely there is a long jumper with many pins in it. The address is set by which pins are absent in a binary format, 1,2,4,etc.,
Controler s3
Now that's old! So do you see a long jumper pin plugged into the board next to the connector? You replaced a board, or added? I am not sure that the S3 is set the same way as the S4 and newer. Can you post a picture?
Im connect a board. I have a problems to configuration IO. If im select output 1 in high (1) lamps dont light. How i can configure IO.
Hello.
How i can cofigure this modul ? This modful is connect with modul AP21.
