How to call Home Position and Second Home Position in GP8 Yaskawa Robot?
  • randz113
  • October 15, 2018 at 7:02 AM
  • randz113
    15
    Good Day!
    I'm new here but I used to program Robot Arm of Yaskawa GP8 and GP12 with or without Force Sensor.
    I just want to ask if it is possible to call Home Position or Second Home Position inside the JOB, is this possible?
    Please teach me.
    Thank you in advance.
    Randz
  • Reintz
    20
    122
    • October 15, 2018 at 12:00 PM
    Hi
    I haven't seen such an option. On a DX200 at least.
    Why don't you just make a JOB names HOME_POS or SECOND_HOME_POS and have the position stored there with a MOV instruction? This way you can call for it inside a JOB. Would that be sufficient?
  • randz113
    15
    • October 15, 2018 at 12:54 PM
    Reintz
    Thank you.
    I already did that instruction before but if there is such a function to call the Home Pos or Second Home Pos, that will be more convenient.
    For example, there is a specific I/O for Home Pos or Second Home Pos so when I'm going to run the program, it will first check if the Robot is in Home Pos or not.
    I think it will be safe if there is such a function to verify the Robot Current position if it is matched to the Home Pos or Second Home Pos for confirmation purposes during program run.
    I'm also searching for the manuals but I still can't find such function that will help me.
    I'm planning to make interlocks in PLC and YRC-1000 to prevent collision.
    Thank you
  • 95devils
    234
    8
    1,948
    • October 15, 2018 at 2:41 PM
    There are no specific functions to have the robot go to the home position or second home. You would have to create them yourself, like Reintz said.
    The home position is always at one position. Where the alignment marks line up for each axis. The controller sees this as 0 pulse counts.
    The second home position is intended from the factory as a position for recovery of alarm 4107, an axis has been moved with power off. The factory puts this at the home position but can be changed.
    The majority of cells that I have done the robot can't get all the axes to the home position or the default second home position due to obstructions in the way.
    The factory doesn't want someone to use this function, if it was available, then crash their robots and call complaining about it. Warranty work would be huge.
  • randz113
    15
    • October 16, 2018 at 2:33 AM
    95devils and Reintz
    Thank you.
    I'll take note on that.
    Right now, I'm doing conveyor tracking and palletizing through the use of Denso RC8 (HSR065A1...) and Yaskawa (GP8).
    Thank you again.
