Hello everyone.
I have a RS20N robot that is going to extract details from casting machine, but have a little problem with the ejectors of the machine - I can't control their speed and I am scared that the force of the ejector will break the robot, if both speeds (robot and ejectors) are not equal. Is there a way to let the ejectors push the robot without breaking it?
Moving RS20N with external force.
lancer1992 -
September 27, 2018 at 7:02 AM -
Sure this is possible. Please use the soft absorber function. You can find the manual in the attachment.
Thank you very much for the information. Now I have to figure it out how to set it up properly.
Your welcome. Best is to play a bit with the different settings, find out which joint are 'pushed' away. These joints should have a lower gain.
- Set the weight proberly with SAGRAV.
- Set free moving direction with SAXYZ (base direction) OR SATXYZ (tool direction)
- Limit free movement with SALENGTH and SADEGREE
- Start softabsorber with SASTART
- Wait a short time,
- Set all the signals, wait for ejectors
- Stop softabsorber with SAENDIf you need more help just ask.
