Hi everyone:
Recently ive been working with a k6sb and ive solved some problems and errors that it had but i got stuck with the next one at the moment i power on the machine, i really need your help and i would appretiate it a lot.
MAKE ABS DATA ERROR FAILED
ERROR NO ERROR STATUS
SV1: 1 00 0000_0000
2 05 0000_0010
3 00 0000_0000
SV2: 1 00 0000_0000
2 00 0000_0000
3 01 0000_0001
SV3: 1 00 0000_0000
2 00 0000_0000
3 00 0000_0000
SV4: 1 00 0000_0000
2 00 0000_0000
3 00 0000_0000
Thats what screen shows, ive been researching for info and ive found on the manual and forums that i need to short circuit the pins 8 and 12 for the S,L,U encoders and 6 and 12 for the R,B,T enconders, the issue is that i really dont know how to do it, since manual doesnt explain it very well and im kinda newbie on this subject, i would like to know if i gotta short circuit them with the machine turned on or how, and if i gotta do it on the servopack board unplugging the encoder cable or do it directly on the encoder cable by disconnecting it, the ones that have alarm are T and L axis.
And ive also checked both batteries, the one on the door of the k6sb and the one on the base of the robot, im gonna replace them both, but as far as i know i gotta replace them after i do the short circuit stuff, let me know if im wrong please.
I really need your help to know if thats the way to solve the problem and how to do it or if i need to do something else... i really appretiate your help, greetings
Robodoc i need you...
