Hello Everyone,
So to sum up a long explanation into something simple, I have been creating .cm files to use on a project that is coming up for me. I have set up .cm files for commenting Utools, Uframes, Style Tables, DeviceNet Boards, DeviceNet Nodes, etc. The problem I am currently having is I have found the command needed in order to comment the Payload "schedule" description, but it is write protected. I have searched and searched for another sys var that has this information, but I have come up empty.
The code I have been trying to use is
The .cm file runs everything else I have wrote, but stops at this command due to write protected.
Another program that I have created into an .LS uses a similar command to write the actual payload and inertia values, which is
Does anyone know another command I can use inside of the .cm file to write the comment?
I have a .pc program that does it somehow, reading from a .csv but unfortunately I don't have the original .kl file to reference.
While the .pc program will do what I need it to, I am creating these .cm files from scratch for my own knowledge, and this one has me stuck.
Any help is greatly appreciated.
