Is it possible to combine two R1 jobs? Job one goes from point A to point B while job two would go from B to C, currently they are set up separately and is using the PSTART way. Could these two be combined? I tried using the Job Pad on MotoSim and just pasting job 2 at the end of job 1 and it gives me syntax errors on every line.
Is it possible to combine 2 jobs on a DX200?
Crowmagnus -
September 16, 2018 at 11:51 PM -
Uhmm...
Hi Crowmagnus,
first let me clarify: if the two jobs are started by a PSTART, they cannot be two R1 jobs, for example one must be a R1 and another one a NON GROUP.So if you want to combine 2 jobs first you have to convert one of them in the group of the other one(They must be the same group)
You can combine two jobs of the same group (as I understand yours are R1 jobs). But you can't just copy-paste the MOV lines in JobPad. Use the virtual pendant instead. To copy line(s) in using thel Pendant - go to the line you want, move right (to the instruction side) with an arrow key, SHIFT + Space, now you can move up/down with arrow keys to highlight more than one line and when the desired line(s) are highlighted EDIT -> COPY. Now go to the ohter JOB, move to the line you want to paste after, move right with arrow key and EDIT -> PASTE.
This will work only if the two JOBs are the same group.
