Hi all,
I have acquired a Fanuc s430iw with an RJ3 controller, but I'm having a hard time setting up the devicenet hardware. Whenever I try to bring a board online it simply gives me a:
DNET-022 Board Initialization timeout error.
*CAUSE: The board initialization routine has timed out.
*REMEDY: Turn the controller off, Make sure the motherboard is correctly seated on the back plane, Cold start the controller. If the problem persists, document the events that led to the error and call your FANUC Robotics technical representitive.
I know the devicenet board itself is fine because I can transplant it into another controller and it works fine.
Any ideas?
