Has anyone ever dealt with this error ? "Signal calculation timeout 794usec" . I received this error when using RSI.
I am using KR10R900, KRC4compact, KSS v8.3.31, RSI v3.2.0 Thank you.
RSI : How to avoid this error? "Signal calculation timeout "
yjtkc -
August 25, 2018 at 3:43 PM -
The problem was solved using the function of RSI_RESET().
Odd behavior was confirmed when using multiple RSI files though timeout error was not found.
For example, it seemed that the public variable of RSI changed by function of RSI_SETPUBLICPAR () was not written well. -
Any variable to be accessed using RSI_SETPUBLICPAR() must be set as public in the RSI Visual editor. By default, almost all these variables are Private.
However, if this was the root cause of the problem, I would normally expect a KRL error message during the execution of RSI_SETPUBLICPAR().
