Is there a way to copy more than one line at a time in the teach pendant. I doing a welding program that welds to two parts and then repeats this again but with an offset. I only seem to be able to copy one line at a time which is quite slow.
ABB copy in teach pendant
David.mms -
August 15, 2018 at 1:33 PM -
Put the program in a subroutine, call the same routine (ProcCall) twice in your "main" weld routine with an offset applied between the two (PDispSet or through workobjects/userframe)
or
Put the program within a For x loop, with an offset applied between the two (PDispSet or through workobjects/userframe) on the second round
or
to answer your specific question.... edit and (I think it was) "mark", tap up/down to mark the area you want and then select copy. -
That seems like a better idea. I've made the main program call some routines but how do you set PDispSet to apply the offset within the routine.
Not the best example, but a sample.
Display MorePROC rPath03() PDispSet posePass3; MoveL pPath3_01,vProcessSpeed,z50,tFlame\WObj:=wobj0; MoveL pPath3_02,vProcessSpeed,z50,tFlame\WObj:=wobj0; MoveL pPath3_03,vProcessSpeed,z50,tFlame\WObj:=wobj0; MoveL pPath3_04,vProcessSpeed,z30,tFlame\WObj:=wobj0; MoveL pPath3_05,vProcessSpeed,z30,tFlame\WObj:=wobj0; MoveL pPath3_06,v1000,z30,tFlame\WObj:=wobj0; PDispOff; RETURN; ENDPROC
I generally use a pose variable, your routine could look something like:Code
Display MorePROC rCaller() rPath3; PDispSet poseP1; rPath3; PDispSet poseP2; rPath3; PDispSet poseP3; rPath3; ENDPROC PROC rPath3() MoveL pPath3_01,vProcessSpeed,z50,tFlame\WObj:=wobj0; MoveL pPath3_02,vProcessSpeed,z50,tFlame\WObj:=wobj0; MoveL pPath3_03,vProcessSpeed,z50,tFlame\WObj:=wobj0; MoveL pPath3_04,vProcessSpeed,z30,tFlame\WObj:=wobj0; MoveL pPath3_05,vProcessSpeed,z30,tFlame\WObj:=wobj0; MoveL pPath3_06,v1000,z30,tFlame\WObj:=wobj0; PDispOff;
I've also used PDispOn in a similar method. -
Do you set PDispset the same way you would set an output. Such as Set D01 through the use of the set function.
No, PDispSet is it's own instruction. IOWan's 2nd example is basically what you're looking for.
PDispSet sets an offset based on a pose(data), you can either use named data or direct input (it has a fancier official name) such as...
PDispSet [[0,0,0],[1,0,0,0]]; Sets it to 0 / the same as PDispOff;
PDispSet [[100,0,0],[1,0,0,0]]; Sets it to 100mm in X -
Why don't you use robot studio to make your edits?
Why don't you use robot studio to make your edits?Arc Welding system and it's not an IRC5 = not worth the hassle if you're just doing a simple copy/paste.
I didn't include the definitions in the example, but they would look something like:
CodeMODULE PROJECT PERS pose posePass1:=[[50,0,0],[1,0,0,0]]; PERS pose posePass2:=[[50,50,0],[1,0,0,0]]; PERS pose posePass3:=[[0,50,0],[1,0,0,0]]; CONST robtarget pPath1_App:=[[1037.49,680,1000],[0.625011,-0.130523,0.764634,-0.087518],[0,-2,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]; CONST robtarget pPath1_01:=[[1037.53,679.92,847.51],[0.625005,-0.130563,0.764631,-0.08754],[0,-2,1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
