Hi people,
I have a virtual machine in VMware to perform tests. When installing it on another computer I get an error when starting KRCStart.
Attached photo of the error. Does anyone know what the problem is?
Thank
Hi people,
Thank
You can't just install KSS in a VM, it's expecting a physical controller to be under it.
You need to use the official KUKA sim package.
I understand, but I've been working on another pc without a problem. The error appears when installing the same virtual machine on another computer.
You did not mention how you created the functional vm image.
You did not mention the version of kss installed in the vm.
The question is like: "my car doesn't drive anymore. What is the problem?"
The installation process was to export the virtual machine that works for me on the work PC and import it into VMware from this other PC.
The KSS version is v8.2.26.
I have already solved the problem, there was a problem with the communication port between physical machine and virtual machine.
Thanks for all.
can you please let me know which version of VMware are you using and how did you manage to instal virtual remote pendant on it?
