Good day, tell me how to do it, milling the place of the lock on the door ka correctly write the program in advance thank you.
krc 2 miling
vto833 -
July 11, 2018 at 2:23 PM -
This is what you hire an integrator and pay money for.
Nobody is going to hold your hand through the entire process, especially if you demand it with grammatical mistakes. -
my friend do not take offense, Google translator translates so I just ask to help me with writing a program with circular motions as correctly as possible
If you wanted to know how to program circular motions, you should have said so in your first question.
If CIRC motions are not sufficiently accurate, then you could try creating an "oval" that is deliberately non-circular in order to counter the robot's inaccuracy. I've attached an example of a program that mathematically generates ellipsoids, using a hand-programmed center point.
