We just purchased a M-710iC/50 robot. In the manual, Fanuc recommends welding two 32mm plates together and pouring concrete around the lower plate along with using chemical anchors.
How important is pouring concrete around the plate? This is not something we can easily do. Would a larger mounting plate with more chemical anchors be recommended? The robot will be used in a variety of applications/ speeds where fast stops are possible.
Thanks!
