good afternoon everyone!
today in the morning at the company where I work I ended up mistakenly erasing a program on the fanuc arc mate 100ic.
I would like to hear from you if there is a way to restore this program without having to play a back up?
ROMARIO
ROMARIO DE SOUZA GONCALVE -
May 8, 2018 at 2:26 PM -
You need to have a backup or an image backup to restore a program that has been deleted.
No way to recover it once deleted otherwise.
Thank you very much for your attention.
is that my last back up was 1 month ago and there were some changes of trajectory I wanted to minimize the adjustment time. -
Você precisa conferir se o seu robô não está programado para fazer o backup automático (acredito que quase sempre é). Geralmente isso é programado semanalmente e é feito de maneira praticamente imperceptível (instantânea). Caso deseje, entre em contato comigo para eu lhe passar as instruções.
hello Guilherme, how's it going?
could you help me identify if the mei robo is programmed to perform back up automatically? and if so what should I do to restore? -
the only active backup on my robot is the back up at power up.
would that be the ideal to restore programs? -
MENU>FILE>Auto Backup
See the device directory (2): Something like "Backup (FRA:)"
