Hi, everyone
I'm a integrator working in Jaguar welding plant. Our project have a bunch of fanuc R-2000ic/165F & 210F robots, now I just met Quick connect & reconnect problem in Ethernet IP configuration for AB1732 module(used on grippers).
The problem is fanuc doesn't report any alarms when Ethernet is crashed suddenly(or cable is unplugged manually) with Quick connect or reconnect function activated. This situation is not safe at all but I got no clue about this. So anyone could PLZ
ikalus1988 -
May 7, 2018 at 10:26 AM -
Note The reconnect parameter was designed for tool changing
applications. Enabling reconnect has the following side effect.
While enabled, all EtherNet/IP alarms relating to connection
establishment and connection time-outs for the corresponding
connection will be masked (will not be posted).
