I will use Pause weaving in our robot but i couldn't find any instruction about it. we know it is active in our controller (DX200) but i need instruction manual for use it. have this function new instruction? how can i use it?
Not sure if there is an instruction for pause weave but what you can do is
MovL
Arc on
weave on
MovL (were you want to stop the weave)
Weave off
MovL. (Were you need to finish the weld.
This is how I manage to weave only where I have gaps and I can even load
Different parameters on those gaps or diferent weave profiles.
Hope this helps and if there is a way to pause it hope someone can show you how.
No, Pause wave is a function and you must purchase.
it work only in coordinate system. these method that you told is not my means.
i know it and worked with it.
What controller are you using???
DX200
Oh ok I'm not sure about DX 200 but DX 100 has a weave on command you can insert from the Inform list you can direct open on the weave on command and set up the type of weave and the amplitude and frequency as well as set a pause not sure if this helps your best bet is to call motorman and have them email the manual to have so you can review this at anytime.
