I need to see the system variables on a Fanuc lrmate r30ia that i purchased used but when I go to the Menus I don't see system variables. I'm assuming it would be under line 8 but it is grayed out. Thanks to anyone that can help.
r30ia system variables not visible on menus
stein -
April 20, 2018 at 4:09 PM -
Is SYSTEM there or not? If it is not FCTN > NEXT > QUICK/FULL MENUS. If it is greyed out???
It is not there. Line 8 is greyed out.
then try toggling the quick/full menus
Thanks, I figure it out. I was setting the config up to use UI/UO. I have mapped flags to them and the values were changing with the input I am monitoring but it wasn't actually working. I was trying to do a "HOLD" (ui:2). So, I have that changed and now I'm getting a MCTL-013 alarm. Any idea what that is? Thank you very much for your help.
You need UI[8:Enable] to be ON.
Got it! Thanks for your help.
New question, I have a flag in my back ground program F2 that flags UI2: hold and I turn it on when DI:102 safety scanner warning goes to off.
Everything is working as I intended but now if I turn the Back Ground program off it still works as planned. What is up with that? Thanks again for your help. This stuff is tuff to figure out for a green horn without this forum. -
I'm guessing UI[2:] is configured to Rack 34 Slot 1 & F[2:] is still on. See if that is the case.
UI:2 GOES OFF (ACTUALLY GOES ON - OFF= IS NORMAL ON) WITH START BUTTON JUST AS IT SHOULD. NOTE, I AM TESTING IN TP-ON MODE.
