Can I get info on the replacement procedure of YCP01BE?, what just plug and play.
thanks
Regards
thanks
Regards
Essentially yes. Make a backup of the cmos.bin if you can. Turn power to the controller off. Loosen the two screws that are the metal door that covers the compact flash. Slide the door to the right. Remove the compact flash. Remove the cables that plug into the YCP. Loosen the two captive screws holding the board into the rack. Pull the board out of the rack.
Slide the new board in. Tighten the two captive screws. Plug cables into the board. Install the compact flash. Slide metal door back to left. Tighten the two screws.
Turn on controller power. Load cmos.bin if necessary.
Well, thank you very much. Now I am still waiting for the new YCP01 from yaskawa.
Did it worked out?
I also want to change my YCP01
have you got any complications?
how to back-up program?
