Hello everyone. I have an old Fanuc s-12 with an RJ controller. The robot is for laser cutting, and has a trepan head as group 2 (J7 & J8). It was without power for 2 weeks, and the batteries were dead, so it lost its master. I brought it up, drove it to the zero marks, and did a zero position master, and calibrate on group 1, then on group 2, and did a cold start. Group 1 took the master without problems, but group 2 is still a mile off. Could there be something that I'm missing, or maybe something I should be looking for? Thanks in advance.
group 2 remaster
memiller1 -
April 9, 2018 at 5:44 PM -
Good morning,
I have had this problem before and heard about this with other acquaintances. But the causes vary a lot so I could not give you the exact solution to what is happening to you.
I could give you some things that I check or did in the past and worked or others told me what worked for them.
check the batteries
check DMR_GRP Master done variable
take it to mark mastered, move it just a little (too little) and return it to mastered only for validate
Thanks for the input. I should've added that I replaced the 4 D-cell batteries in the base before remastering. I checked the DMR_GRP variable, and it was true.
Might be stating the obvious here, but did you calibrate after you were done on group 2?
Yes, I've calibrated after the master. It's the weirdest thing. Axis 7 (G2:A1) is trying to go to a position near 78 degrees, but there's a total of around 33 degrees of movement in the axis. With zero position in the center, it can only move around 16 degrees either direction.
