I have fanuc S430 iw with r j3 controller I did int start after cold start but teach pendant give error DICT-004 dictinory not found and keeps staying controller starts menu what can I do where can I find dictionary don't have any back up or orginal software please help If some body has recovery back up ill pay for it
Fanuc rj3
granitecity -
April 3, 2018 at 10:33 PM -
Was the robot working before you did the init start?
Why did you do the init start?
Yes it was working because i bought used one
Did you take a backup of the working robot before you did the init start?
I didnot back up i want to erase all existing data
From the error code, it sounds like you will need a software reburn, which could be extremely expensive if your robot is not licensed through Fanuc.
The first thing I was ever taught: before you make any changes, no matter how small, always take a backup.
I would add, if you are ever going to do anything as drastic as an init start, make an image backup as well. On older robots with a memory card slot, it only takes a few minutes. Restoring from an image takes only a minute or so.
Post Script:
From the controlled start screen have you tried FCTN > Cold Start?
Yes i did but end up same error
