Help mirroring input bits on the output side in the background?
  • ashwinmudigonda
  • March 19, 2018 at 7:05 PM
  • ashwinmudigonda
    43
    I need to reflect a set of bytes coming from the PLC on the output. So if IN 500 is on, I need to set OT 500 to be high. How do I do this in the background and not using a job?
    I am running a MH50 robot on a DX 200 controller.
  • 95devils
    234
    8
    1,947
    • March 19, 2018 at 7:25 PM
    That would be done in the Ladder Program or Ladder Editor.
  • ashwinmudigonda
    43
    • March 19, 2018 at 8:37 PM
    I figured that much through the manuals, but what do I add to the ladder?
    Find the relay that matches teh input and connect it straight to the relay that matches the output?
    I tried to map input 17 to output 17.
    I added a rung and set the relay on the left to be 00030 and the one on the right to be 10030, but the ladder won't compile.
    I also tried to set the relay on the right to be an OUT.
    How would the program look like?
    STR #00030
    OUT #10030
    I tried doing the above in the mnemonic editing window, and could not get it to compile
    Edited once, last by ashwinmudigonda (March 19, 2018 at 9:29 PM).
  • tonygast
    244
    • March 20, 2018 at 1:05 PM
    You can not duplicate outputs in the ladder...
    If an address is located within a GOUT or a BMOV .... you have to "break" it out into individual rungs
    GSTR #2xxxx if you change like this it will mirror 8 bits
    GOUT #3xxxx
    STR #2xxxx This change will mirror a single bit
    OUT #3xxxx
    STR #1xxxx
    OUT #3xxxx
    STR #1xxxx
    OUT #3xxxx
    STR #1xxxx
    OUT #3xxxx
    STR #1xxxx
    OUT #3xxxx
    STR #1xxxx
    OUT #3xxxx
    STR #1xxxx
    OUT #3xxxx
    STR #1xxxx
    OUT #3xxxx
    STR# 70017
    BMOV 2xxxx, 16, 3xxxx mirrors 16 bits
    Oh, well
    Edited once, last by tony gast (March 20, 2018 at 1:13 PM).
  • Too_Fast_46
    43
    • March 20, 2018 at 3:06 PM
    Quote from ashwinmudigonda
    STR #00030
    OUT #10030
    In addition to what Tony said, you cannot control a #1XXXX address with the CIO. Your ladder likely would not compile because of that.
  • tonygast
    244
    • March 20, 2018 at 3:59 PM
    On your universal outputs you can only "OUT" 3xxxx
    1xxxx are internal bits
    Oh, well
