Hello All,
I am using a robot with v8.3 and spot tool plus. I was checking some pressures on a weld gun and noticed them to be off by about +/- 50 pounds. I decided to re calibrate the pressure. When I was calibrating, everything appeared to be correct, but when I did a manual press, the pressure was still off. I then noticed that the pushing depth on the calibration screen was different from the pushing depth I was using in the pressure schedule. I changed the pressure schedule pushing depth to match the calibration, and then the pressure was bang on.
Should I be calibrating with the same pushing depth as I am going to be welding with?
Thanks,
SEAN-DUDE
