GOOD MORNING GUYS
Experts in the house please look at this error message logic and tell me what i am doing wrong
;Abfrage ob Wiederholung od. Weiter
msg = {modul[] "BSA", Nr 7, msg_txt[] "FEHLER BEIM SCHWEISSEN!"}
SK[1] = {sk_Type #value, sk_txt[] "AUTOMATIK"}
SK[2] = {sk_Type #value, sk_txt[] "MANUAL"}
IF NOT $EXT THEN
SK[3] = {sk_Type #value, sk_txt[] "WEITER"}
ENDIF
nHandle = Set_KrlDlg (msg, par[], SK[], opt)
IF (nHandle > 0) THEN
WHILE (Exists_KrlDlg(nHandle, keynumber))
WAIT SEC 0.1
ENDWHILE
ANSWER=keynumber
ENDIF
IF ANSWER==1 THEN
;Schweissstart ruecksetzen
oSTART_SCHWEISSEN=FALSE
PULSE(oERROR_RESET_FK,true,0.5)
MUTTER_AUF_STIFT ()
ENDIF
IF ANSWER==2 THEN
PULSE(oERROR_RESET_FK,TRUE,0.5)
ENDIF
IF ANSWER==3 THEN
bPWH=TRUE
ENDIF
As you can see from the logic the Robot should only Show the 3rd button when i am in T1 Modus
but it still Shows this third button when i am in Automatic
