Hi , I am new to KUKA ROBOT and I am facing some problems,
I am trying to send signal from my WAGO io to the KRC4 IO module, but i the signal is weak and undetectable, i can see the led flash(very weak) but no signal. So is it possible to do so or any other methods? since both io are using 24V.
2nd question was is it possbible to pull out the connector of the Beckhoff IO ? It seems to be build in. Cuz i am using the regular way which put a flat screwdriver to open up the port of the IO and put my wire in, but not for this beckhoff module.
