Hi! I have a query for you. I've created a main taks and a background task with multitasking on RobotStudio. So far everything alright. Before this question comes up, the robot has the multitasking option set up. The issue I'm dealing with is that I can't create the background task on the flexpendent. I can load the main task via USB or LAN, however, I fail to load the second one. As a matter of fact, if I set up a relationship between the PC and the Robot, when transmitting the tasks, the second one is not visualized and as a result, I cannot tick it.<br><br>I would be very grateful if anyone could help me solve this conundrum?<br><br>Thank you beforehand.
I cannot create a background task on the flexpendant
aitorlgse -
January 27, 2018 at 11:55 PM -
Did you create the task via the control panel?
Thank you for answering. I'm on it. After reading tutorials, I reached the conclusion that what you mentioned was the solution, together with setting the task as normal. Even though I think I've worked that issue out, the program doesn't work as expected. But at this point, I must debug the programming and i hope it works. Thanks a lot!
It's much easier to do all of this in robotstudio...
