I have a KRC4 with installed KSS 8.3. I need to send data using EthernetKRL to a server, located on my KRC4. There are a mistake number 14 while execution of function EKI_Open() when I try to make it using local host (IP: 127.0.0.1). If I use IP 192.168.0.1 or if I connect to my server another client using IP 127.0.0.1 on Windows 7 Embedded of KRC4 everithig is ok.
Can I use a localhost with EthernetKRL and how if it's possible?
Thank you in advance!
XML-file
<ETHERNETKRL>
<CONFIGURATION>
<EXTERNAL>
<IP>127.0.0.1</IP>
<PORT>54600</PORT>
<TYPE>Server</TYPE>
</EXTERNAL>
<INTERNAL>
<ALIVE Set_Flag="1"/>
<BUFFERING Mode="FIFO" Limit="1"/>
<BUFFSIZE Limit="16384"/> </INTERNAL>
</CONFIGURATION>
<RECEIVE>
<RAW>
<ELEMENT Tag="Buffer" Type="BYTE" Size="1" Set_Flag="2"/>
</RAW>
</RECEIVE>
<SEND/>
</ETHERNETKRL>
