I need help with moving something on the conveyor. I have read the conveyor part in the manual for MotoSimEG-VRC and still do not understand. If someone knows how to do this can you please message me!
Are you trying to use model scripts to move the part or conveyor tracking? Scripts are fairly easy to explain. Conveyor tracking in EG-VRC is complex to explain the pieces over the internet.
I sent you a PM.
What is in this picture is the model script editor with a script name ADDX6WORK. The ADDx6 is the script instruction that is the robot IMOV instruction. From where ever the WORK (brown box) is, it will move -25 mm in the X direction to simulate coming down the conveyor. In I/O Event the script was tied to Output 9. I created a job that would pulse output 9 then delay then pulse again. I could have set up a counter so that this runs 6 times. It is not the smoothest way but can look realistic, conveyor surging.
What is in this picture is the model script editor with a script name ACT. The ACT is the script instruction that can move the brown box down the conveyor from point A to point B. The WORK (brown box) has a starting position of 405 and an ending position of -275. The script will start immediately and complete in 3 seconds. In I/O Event the script was tied to Output 9. I created a job that would pulse output 9. The timer in the job is so that the script would finish running. I did this since I don't have anything else for the robot to do. This is much smoother.
Okay, that makes sense. I am going to try this.
