Need a little help with moving numbers from Mitsubishi PLC through Yaskawa Ethernet/IP. For Instance, I need to move a number into the Robot controller in order to change either the X or Y position according to different place movements. The Ethernet/IP card allows 8-bits or 1-byte. It would be nice to move decimals up to 32-bits ... then manipulate the data into the element I need. I do not see an ability to Concatenate bytes in the Inform language. I do know that there are programs designed to handle this problem, but I need to keep it simple without unnecessary expense. Any help with transferring 16 or 32-bit numbers would be greatly appreciated.
9/29/2017 Thanks ...
