I have an R30ia controller with an RJ3 teach pendant. The controller was swapped out before my time here. Is there a way to get an LS file from the controller? The teach pendant is not giving me the option. What if I were to temporarily swap the teach pendant with a newer one?
Thanks!
Controller/Teach Pendant Swap
BRich2017 -
August 17, 2017 at 3:24 PM -
using the copy method from file does not give you the .ls option? are you in quick menus by chance?
LS files are generated when you print out the program, under FILE -> UTIL -> SET device
chose USB or Memory device, etc.
Then under SELECT -> NEXT -> PRINT
your TP program will be printed (saved) as LS file -
also it's possible you need to change the sysvar: ASCII SAVE to on
