.KL file for loading descriptions from excel. Can anyone share a copy of this with me? I had one a while back but cant seem to find it anywhere!
KAREL loading descriptions from excel
Iprogram -
August 17, 2017 at 3:10 PM -
I was just about to ask the same question, but I used the search like a good robot forum member.
Any body know about this?
I was just about to ask the same question, but I used the search like a good robot forum member.Any body know about this?
How does one use it? Its a .xls that is supposed to generates .kl?
Sent from my SM-G892A using Tapatalk
For example you can export an excel sheet to a .csv file and then open it in Karel and write a loop to interpret it. Knowing the table structure of the file and the sign used to separate columns, it's possible not only to assign desired names to given signals, but also edit their properties, like polarity.
i did a search but didnt come up with anything. Care to share your search results?
At the very top of the forum is a special section for Fanuc tools that others have made.
https://www.robot-forum.com/robotforum/too…anuc-robotics)/
I believe the one you want is this one.
At the very top of the forum is a special section for Fanuc tools that others have made.https://www.robot-forum.com/robotforum/too…anuc-robotics)/
thank you but i did find that one. I am looking for the KAREL code to extract the data to excel and to load it. Need the actual text or .KL file for how this is done.
it's actually pretty straightforward, you have to open a file (.csv probably; with a dedicated built-in), interpret it and edit the comments with a dedicated built-in, until EOF is found in the file.
