If I go Menu-->IO-->Ethernet/IP
I get a menu showing "Connection 1" input and output of 4 words. If I want to change this how do I go about doing this? At the top of the screen it says read only.
Is the connection <running>. I do believe you have to disable the connection to adjust the settings
Well that was simple... Thanks for your help.
