Where would the settings for the "Default Motion" shortcut be. I need to change the default from "L P[] 100mm/sec CNT100" to "L P[] 10mm/sec CNT25"
Default motion settings
sawbones -
August 1, 2017 at 5:14 PM -
Open the default motion menu (on a paint robot it's Point, GunOn, Paint, GunOff). You should be able to select from 4 options then.
At this point, F1 should be labeled "Ed_Def" Hit that, and you can change any on the entries.
