Hello All,
We recently had to replace one of our laser sensors due to internal contamination (coolant residue). I believe some residue got on the laser module inside of the unit and was skewing one of the laser lines causing adverse effects on pick positions. Due to the age of the sensor, 8/2010, Fanuc CRC says that they can not rebuild it. Does anyone on here know of a place that does this type of work that is reasonably priced and reliable? Part number is: A05B-1405-B131
THANK YOU!!
