Hi.
I have to maintain a KUKA robot, fix some bugs and improve the program based on the client requirements in a dynamic environment.
I have tried different ways to set up the virtual pendant to have something to work with in offline mode. I tried to install the controller image on my laptop but I couldn't. Apparently it only works with specific hardware. Is there antyway to connect RoboDk to virtual pendant?
Thank you!
Is there any way to use virtual pendant without connecting to real controller
NavH -
July 21, 2017 at 4:13 AM -
As far as I know, you can not directly install KUKA controller image on laptop. If you want to work on the real controller this way you can remotely connect to the controller using Workvisual and Optional Package through which you could access KUKA "visual panel" on your pc.
Thanks. I'll try it.
