Help me! I am trying to execute the following program in automatic mode, and it only runs while I hold the start button. Can someone tell me why it doesn't run continuously after I press the start button once?
Program only runs in automatic while holding the start button
ronciak -
July 7, 2017 at 9:06 PM -
So you don't have to download:
The program Set_foam_parameters just sets an analog output and 2 variables.
The
Display MoreDEF Purge_Nordson( ) ;FOLD INI;%{PE} ;FOLD BASISTECH INI GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( ) INTERRUPT ON 3 BAS (#INITMOV,0 ) ;ENDFOLD (BASISTECH INI) ;FOLD USER INI ;ENDFOLD (USER INI) ;ENDFOLD (INI) Set_foam_parameters() LOOP Start_foam() WAIT SEC 7.35 Stop_foam() WAIT SEC 6.07 ENDLOOP END
Normally You have to press the start button until the BCO is reached. The release and press once again.
May be Your program has not reached BCO (first programmed position), so You have to press start all the time until the first movement will be finished.For a first test try a ptp $pos_act after the "init" or set_foam_parameters.
Danke schön!!!
I'm such a dummy. I should have figured that out myself.
