Hi Everyone,
I've been stuck on this problem for about two days now and I'm really at a loss. I'm trying to setup an RJ3iB arm with a Lincoln PW 455M and I'm running into a couple problems that I believe trace back to the DeviceNet board.
So, when I turn everything on, the TP says "Weld EQ Online", but then if I try to run a weld program it throws an Alarm: "Arc - 046 Weld EQ Offline"
If I go into I/O > DeviceNet, all the boards are offline. If I try to switch them online, they each throw an error. If you check the board list, it doesn't recognize anything.
Once I try to put a board online, the TP Alarms say: "DNET-004 Board Init Failed" and "DNET-017 Board Not Found"
And finally, the DeviceNet board has two flashing red LEDs on it. I can't find any troubleshooting guides that will tell me what this means, though.
I'm very new to all this, so I would really appreciate any help.
Thank you!
James
