Hello
I am trying to use PCDK to set robot number registers from a PC.
Which type of cable we use between PC and Robot 200ic R30ia.
Is there any other hardware we need?
FANUC Robotics PC Developer's. Kit cable
dzrobot -
June 14, 2017 at 9:21 PM -
Hello, you can use a simple cable Ethernet between PC and controllers.
And install a iPendantControls_V8.10.52_Rev.B, with this extension, you can write a registers, points registers with your PC
Should i install iPendantControls_V8.10.52_Rev.B on PC or robot controller ?
with this install do I still need PC Developer's. Kit installed in my PC ?Thanks again
Other info. I would like to update the robot R[] registers with a PC program (VB) not manually.
Install iPendantControls_V8.10.52_Rev.B on your PC, open robot web browser in roboguide and it's done.
Look the address ip of your robot (in the menu --> System --> Host com --> TCP-IP --> Press Enter). : example, if this address is 192.168.0.11, insert in your pc this address : 192.168.0.10
And with this application, you can update the Registers with your PC (Values or Comment).
