I have a M98 controller with a DSQC345C dc link which is broken. I also have a DSQC345G dc link from a M2000 controller which is still working fine. Can I use this one in the M98 controller?
Dc-link m98 irb 6400
Kroket -
May 19, 2017 at 9:32 PM -
Hello.
Apparently you jot a mismatch, dcling with G is DSQC358G i.e. DC4 with ext. axis drive U.
In general, drives from 6400R cant' be used at 6400.
BR, Olda. -
That is not correct the unit is 345G and it is a dc link not a drive unit.
I'm very curious since I don't have a listing for DSQC345G, do you have the art. (part) number? I checked the ABB website for all 3HAB8101 numbers and couldn't find it.
If you have a DC4U rectifier, you may be able to use it if your software can select DC4 during an INIT start or query load. The amp portion can go unused but you may want to consider changing the dynamic braking resistors to handle the higher current capability.
