hello all,
I've recently attached a cnc cutting torch with pilot src to an sk16/ MRC combo. My question is what is the appropriate pin connection to signal on/off to the torch. The trigger is a simple make/break switch to signal the pilot. Is there a specific pin or will any d in d out work?
kind regards and thank you
signal arc on MRC
robodweeb -
May 5, 2017 at 11:49 PM -
Hi, if you have a MEW01/02 board installed , its a handy way of controlling plasma,tig and other machines .
If you initialize MRC as a welder you have the Arcon - Arcoff features on the TP for quick means of control.
If you haven't access to MEW01 PCB then Yes, simply use the Digital Outputs to control external machines , interface with a relay to achieve isolation , its not a good idea to mix power supplies.
If you don't have Instructions manual for MRC , which shows all the I/O , let me know & ill send it . -
Coolio! thanks Pcarbines for clearing that up.
