Has anyone encountered this error code... Error code E1180 Soft Limit Error (G1) I would appreciate any help anyone could give me.
Thanks Randy.
Thanks Randy.
Soft limit error simply means the particular axis has been moved too far and has reached it's software defined limit. You should be able to jog the axis back off. Reteach a point or points if necessary.
Thanks for taking time to post a reply, I appreciate it.
In case you have to re-teach positions you have a big problem, it means something is wrong with the calibration of the external axis G1.
If calibration has not been done, it is impossible to program positions outside the working range of any axis.
In case you ran into this problem during programming, jogging the external axis, then there may be no problem at all, you just moved the axis too far.
Another possibility is using calculated shift functions or tactile search functions which may produce shifts beyond the working range.
regards,
robotwelder2
