How to Set ACC Limit in Fanuc M900/30iA Robot
  • swapnil
  • April 9, 2017 at 12:32 AM
  • swapnil
    38
    Hello
    I want to Put ACC Limit in Fanuc M900/30iA Robot as my Handling tool 7'th axis arm s too long & if someone exceed ACC Limit then SERVO-046 Alarm occured problem.
    :help:
    All power is within you; you can do anything and everything. Believe in that; do not believe that you are weak; do not believe that you are half-crazy lunatic, as most of us believe now-a-days. You can do anything and everything, without even the guidance of any one. All power is there. Stand up and express the divinity within you--Swami Vivekananda
  • USURP_RUR
    8
    162
    • April 9, 2017 at 4:10 AM
    You can set the min and max of your ACC scale in the window;
    MENU--System-- F1[TYPE] Config
    I hope I understand your question correctly.
  • USURP_RUR
    8
    162
    • April 9, 2017 at 4:31 AM
    Also I want to say that this ACC motion option should not normally have to be included in your position instructions, your moves.
    Is your robot's Payload(s) schedule(s) set accurately?
    Are the cooling fans in the Controller cabinet working, and providing good cooling air flow?
    Do your discharge resistors show the correct resistance readings? (Usually 9 ohms or 16 ohms for the R-30iA controller)
  • swapnil
    38
    • April 25, 2017 at 7:08 AM
    Hello All...
    Yes I found this setting :merci:
    USURP_RUR Yes Everything is fine but due to extra length problem we need to keep min ACC max.100 as per Fanuc India. :merci:
