I have a problem, im using computer vision to detect an object which the robot has to pick up. The computer sends the coordinates and the rotation of the object.
How do I make the tool rotate correctly to the rotation so the gripper can pick it up?
Only rotate tool ?
UR10Robot -
April 6, 2017 at 3:12 PM -
Maybe you need to send commands with joint position
Is the data from the vision system in degrees? You might need to convert it to radians for the UR.
Hi! Did you find a solution to this issue?
If the camera is returning Rz in degrees you must use d2r() to convert it to radians, the pose_trans() function requires x, y, z in meters and Rx, Ry, Rz in radians.
