Is it even possible to do a measurement of a hole diameter with irVisison 2D without a too complex code? If so, how low can I get the error down to? I have a J6 mounted sony analog camera.
irVision measurements
dlok -
March 20, 2017 at 12:52 PM -
Fanuc offers the ability to perform length/width inspection with the iRVision Inspection Application. The code isn't much different than other vision processes but you will need the inspection option to perform measurements.
I have yet to use iRVision to perform measurement and Cognex products might be better suited for the task.
The inspection vision process comes with any version of iRVision, and you can calibrate just the process with a simple grid if you want to measure mm rather than pixels.
