Hello Everyone,
I found this information in the manual and wanted to double check if this is the only way for transmission of offset data between slave and master robot? R30iB iRVision Manual > iRVision 3D Laser Vision Sensor Application Operator> Vision Application>Pg 148
"The data transfer between robots function is an option which sends and receives the register or position register data between robots over Ethernet. The data is transmitted by executing a Karel program"
Is Karel program the only way?
Thank you.
