  4. Kawasaki Robot Forum
Group and kawasaki
  • Mr.Pavel
  • February 8, 2017 at 7:33 AM
  • Mr.Pavel
    18
    I need infomation about instruction/command GROUP. I saw this instruction in AS program, but i do not know what is done this instruction. :wallbash:
  • kwakisaki
    694
    4,770
    • February 8, 2017 at 1:24 PM
    Hi
    I have never come across this AS Command, which Manual is this contained in (Manual No.?)
  • Mr.Pavel
    18
    • February 8, 2017 at 2:19 PM
    I did not find this AS Command in manual. But I have backup Ikat1701(attached). This backup have .PROGRAM main_a(). Program have step GROUP 1.
    And K-roset know this instruction (screeenshot attached).
    Files
    2017-02-08_15-47-58.png 703 Byte – 40 Downloads 2017-02-08_15-47-58.png_thumb 3.42 kB – 26 Downloads Ikat1701.txt 163.86 kB – 21 Downloads
  • kwakisaki
    694
    4,770
    • February 8, 2017 at 9:03 PM
    I see what you mean.......
    - There is only 1 occurrence of the 'GROUP' command in your filesave......
    - I see its an ARC Weld 8 axis system too......So I assume there are 2 external axes connected - maybe positioners/rotary table.
    - I have located some reference to this called Separate Control Setting Functions.....but cannot get any manual...but the manual no. is 90210-1229DEC, if you contact KHI, or your local distributor, I'm sure they could provide this for you.
    If you look at the Dedicated Input/Output Signal sections of the backup, you can see references to GROUPS there, so as a complete guess I would say it may just be turning on a dedicated output/ looking for dedicated Inputs as part of a GROUP of robots/axes/positioners/NC's operating so global enabling/reset/start etc can be carried out........ ???
    The manual I mentioned above, may help 'connect the dots'.
    Hope this helps............
    Edited once, last by kwakisaki (February 8, 2017 at 9:54 PM).
