Good afternoon.
You must configure the robot module OMRON NX-EIC202 .Delayu the following settings:
IP Address 192.168.0.3
Vendor ID: 47
Device Type :12
Product Code: 1660
Input Size (bytes):6
Output Size (bytes):4
RPI:32
Assembly instance (input):100
Assembly instance (output):150
Configuration instance:0
Advanced configuration:
I/OData Type: 8Bit Bytes
Timeout mult:Default
Reconnect:True
Major Revision:1
Minor Revision:2
Alarm:STOP
Quick connect:FALSE
RPI :32
Transport type:UNICAST
RPI:32
0-T:Run/Idle Header
T-0:Modeless
After this connection is pinged, but does not RUNNING.
Tell me what I'm doing wrong?
