I have the KRC2 Robot and running on Win95 operating system and KRV V4.1.7 SS.
I installed KRC V5.4 SS because I can not use the CP5614A2 Profibus card on Win95 operating system, But this time I have come across an error like this. DeviceNet card ok, Profibus card ok but it gives the error in the picture.
What should I do in this regard?
Can you help me?
Thank you.
DSE 1 program boot up failuer in KRC V5.4
Blackeyed -
December 9, 2016 at 6:14 PM -
I don't think its going to work.
To move on from KSS4.x to KSS5.x you need different version on MFC/DSE combo.
On the PCI card sticker (either MFC or DSE) there needs to be clear indication that this is version C33.
KSS 5.4.x does not have krc2.bin file in DSE folder. -
Thank you for your answer. what should I do?
The DeviceNet (Wago I / O) plugged into the green socket on the MFC / DSE combo card and DeviceNet I/O is working properly.
Should I change the card or do I need to copy the file?
If you can not run KRC v5.4, what is the driver for the CP5614 A2 on Win95 for KRC V4.1.7?
Please help me.MFC / DSE combo card images are attached.
Can you help me?
Thank you.You can't use WinXP + KSS V5 with installed DSE. KSS V5 need DSE IBS C33.
"I can not use the CP5614A2 Profibus card on Win95 operating system"
You can use CP5614A1 Profibus Card on KSS V4 but you need correct article number. New Siemens card CP5614A2 does not work with KSS V4. -
Thanks for your answer fluke
