To use the KCL window I have to change the variable $RMT_MASTER to 1 (default = 2). However, after a couple of minutes this var changes back to 2. How can I avoid this ?
Kind regards
Luc
Kind regards
Luc
are you changing the variable in the variable list or using the following command? set var $rmt_master=1 then press enter
we typed in the command in the Karel class and it seemed to stay until we restarted the virtual controller
Thats the way I do it...
Regards
Luc
