Hello every one , I don't understand very well abouth the X11 sokect label , some people can help me ?
Can you tell the label means ?
Thank you .
Thank you .
check pdf below, It should be clear, what is the meaning of all signals.
Test output is a source of 24V generated by KRC.
Channel A and channel B are both 24V but different pulse modulation (therefor you cannot mix them)
KRC expects to see close circuit. Output voltage that it generates must come back to a given input signal to close the circuit (estop, safety gate...)
Because these signals are safety related everything is dual channel. Both channels (A and B) has to be close/open at the same time.
animisiewaz
great nickname
Thank you for yours reply
